BigSaint, I was standing there when The PE guys showed up. I won't tell you how much begging I had to do But it helped that I had a ETH. They (PE)ran out of time and did not get to test the Comp on a ETH. I missed the trip to see the Injector pumps as I was trying to get my hands on the Comp Box. It took the other PE guy (Bret's Partner?) and me maybe 15 or 20 min to install.
BigSaint,BartTimothy,
I did have the 275's and Power Edge Comp when I Dyno'd at DD. The RWHP was 359. 2 (which according to Bpine Calc's rounds up to 360 HP)
and over 3,200 RPM it was still above 225 hp where it normally drops off the scale.
The RWTQ was 735. 6
P. S. I just locked my keys in the truck getting my Dyno Sheets.
I just estimated the 425HP from many opinions of the fellow bombers. The DDIII's should be good for 65HP over the 275's. I did not get a chance to Dyno again. Does any know of a good Dyno in Phx or Tucson?? I am dying to get solid Dyno #'s...
CCahill'
Bret / PE said that they should have the defueling program done soon. And I think he said we could just upgrade our early Comp Boxes. The Comp box set on level 1 with the fueling set on low smokes very little even with DDIII's. I am not sure if it is OK but I have been changing to higher levels under power. It works great. I found that if you leave your finger on the button it does not kick in all the extra power until you lift your finger.
OO, LMAO
Didn't I mention that I was concerned with over boosting???
And I still want to know what you are hiding in your Intake Horn!!
Bart I also heard that SS's dyno was reading high. I wish I had time and $$ to get my truck run on both. Especially now to see the actual #'s. .
The guys at DD sure took care of me and Big thanks to Lawrence who fixed my exhaust manifold bolts that had fallen out. ( for those of you who don't know there is a TSB for fixing this problem. )
HVAC, Adam II and me surely have a APB out on us as we were having a great time. I had Peter with me and I was trying to Slip his clutch. I even dropped the clutch at over 2500 and my truck just launched. The only thing I acomplished was to get Peter looking at buying New CTD trucks! I had some tire spin but I have found out that 265 Mich's with no tread left really hook up.
Tell Adam that I had my truck weighed today and it was 3,805 Kilos or 8,371 lbs . That was after I removed some stuff out of it when I got home. So I'm ready for a rematch. We ran atleast 20 times and it was a Tie every time. I have never seen two Completely different trucks so evenly matched. It would have been great at the track.
TomGolden, As stated above my Generic 2001 ETH turned a 359. 2 RWHP with the new PE Comp box and 275's. Brete was a little suprised that it pulled that high. I wonder if everything was set right on the dyno. Maybe they had adjusted it alittle for Bpine.
It is definately stronger with the DDIII's. Now I am concentrating on Lowering EGT's. !
Peter, which clutch was in Bully Dog's truck?? Have you ordered your CTD yet?
KwikKurt ---New Sig to come soon!!
