Archived Spacer Between Spring And Axle
Archived ESS help
Archived just put in DD, no disengage
I Have A 91 W250 That Got Hit In The Left Wheel Area And Sheered The Aliment Pin On The Spacer Block Under The Spring. I Can't Find A New Factory Or Factory Type Block Anywhere, 3 Inch Front And Back. I Did Order A Set From A 4x4 Shop But The Blocks Are Sloped. Does Anybody Know Where To Find A Factory Replacement Or Will These Sloped Blocks Work? Or If I Can Use The 5 1/2 Inch Blocks Off Of A 92-93? Other Than Changing The U Bolts, I Have To Get This Truck Rolling Asap. Any Help Would Be Great.
1991 W250, Auto, Banks Stinger, 9499 Miles
51/2" blocks will work with longer "u" bolts you can also mill these blocks down as they are solid then all you have to do is drill out the centering pin hole after you mill the top down. I did this to lower my 02 and it worked well.
