Speakers for 2003 3500
Steering help!!!!
ReadyLift Leveling Kit
I see Amazon has Infinity speakers on sale, I think I read that I have 6x9's front and 6. 5 rears, just went to look, how do you get those grill cover things off ? I tried and quit, I have a bad history of messing up on this sort of repair.
Thanks- Steve
I'm not 100%on an 03 , but on my 06 when I upgraded speakers to Alpines the entire door panel has about 4 scres then lifts off. Nime is a reg. cab so the entire b piller comes off in one piece also much hrder then the front doors, but not to hard to have to pay somebody else. Justtake your time and make sure all to screws are out before you try to tug on any panel .
Steve,
First is you have to remove the door handle. That takes a T25 bit w/ a long extension to get past the handle. After that there are like 2 phillips screws holding the inner plastic to the door frame. The plastic panel rests on a couple of tabs on the bottom. Once you get the plastic out of the way, there is a sheet of sound deadener on the inside. pull that away and then you should have no problems accessing the speakers and the wiring. Good luck
