Special EZ for HO??
Tire cupping problem- Long
Miss at idle again
You don't need a special EZ box for a HO. I asked when I bought mine at DIS and he said they were the same whether you had a regular or HO.
JM
High Idle
It is a high idle kit put together by Harold Bowers. Basically it is a solenoid that you mount by the throttle in the engine compartment. When you engage the solenoid, it holds the throttle open to around 1150 rpm. It's the low cost alternative to a full blown adjustable electric high idler.
He puts together the whole kit: solenoid, mounting bracket, switch and wiring. Hopefully I'll get my pics of it installed scanned in soon so I can post them up to give everyone a better idea of how it works.
When I got bought one, it was around $35 if I remember correct. Just use the link in my sig to drop him an e-mail for more info.
JM
Map plug
The only difference that I know between the EZ boxes is in the Map sensor plug. This varies with the year of your truck. I'm not sure which years had the triangular version, earlier than 2001. Mine is set up as a flat 3 pins in a row. Just something to be aware of when you purchase a used box from a consumer that had a truck different than your year.
Scott W.
