2nd Gen Non-Engine/Transmission speedo gear question
i recently changed my '96 3500's tire size from 235/85R16 to 225/75R16 and would like to know what speedometer gear i need to get it calibrated correctly. the truck has a 3. 54 rear end gear and an automatic transmission. i called the local dodge dealer, but they were little help to say the least.
Here is the chart
Create Parts List
21P-Speedometer Pinions
110-Speedometer Pinion
Item Qty Rqd Part Number Qty Line Series Engine Trans Description
1 PINION, Speedometer Drive
5206 7637 1 37 Teeth, LT215/55R16D All Terrain, LT215/85R16E BSW ON/OFF, P245/75R16 RBL RTS, LT215/8516E All Season, 3. 92 Axle Ratio
5206 7632 1
5206 7636 1
5206 7635 1
5206 7636 1
5206 7635 1
5206 7628 1 28Teeth , LT245/75R16C BSW,P265/75R16 OWL ON/OFF,3. 21Axle Ratio
5206 7629 1 29 Teeth, P245/75R16C BSW, P245/75R16C OWL ALL SE,P275/60R17 BSW,P245/75R16 RBL RTS,3. 21 Axle Ratio
5206 7629 1 29Teeth, LT215/85R16 All Season, 3. 21 Axle Ratio
5206 7630 1 30 Teeth, ALL 225/245/255 R15/16, 3. 21 Axle Ratio
5206 7631 1 31 Teeth, LT215/85R16E BSW, 3. 55 Axle Ratio
5206 7630 1 30 Teeth, P265/75R16 OWL ON/OFF, 3. 55 Axle Ratio
5206 7631 1 31 Teeth, LT215/55R16D BSW, LT245/75 R16E BSW,
5206 7632 1 32 Teeth, LT215/55R16D All Terrane, LT215T 215/85R16E BSW ON/OFF,P245/756R16C BSW, P245/75R16C OWL, 3. 55 Axle Ratio
5206 7632 1 32 Teeth, P275/60R17 BSW,P245/75R16 RBL RTS,LT215/85R16E All Season,, 3. 55 Axle Ratio
5206 7633 1 33 Teeth, ALL 225/245/255 R15/16, ALL 225/245 Tires, 3. 55 Axle Ratio
5206 7633 1 33 Teeth, P265/75R16 OWL ON/OFF, 3. 92 Axle Ratio
5206 7635 1 35 Teeth, P265/75R16 OWL ON/OFF, 4. 10 Axle Ratio
5206 7635 1 35 Teeth, Tires ALL 245/R16, LT215/85R16E BSW,LT215/85R16E BSW ON/OFF, 3. 92 Axle Ratio
5206 7635 1 35 Teeth, P275/60R17 BSW, LT215/85R16E All Season, 3. 92 Axle Ratio
5206 7636 1 36 Teeth, ALL 225/245/255/ R15/16, 3. 92 Axle Ratio
5206 7636 1 36 Teeth, ALL 225/245 Tires, 3. 92 Axle Ratio
5206 7636 1 36 Teeth, LT245/75R16E BS All Season, LT245/75R16E BSW All Terrain, LT245/75R16E All Season, LT245/75R16E OWL All Terrain, 3. 92 Axle Ratio,
5206 7636 1 36 Teeth, LT215/55R16D BSW All Season, LT215/85R16E BSW All season, 3. 92 Axle Ratio
5206 7638 1 38 Teeth, All 225/245 Tires, 3. 92 Axle Ratio
2 6035709 1 O RING, Trans Speedo Adapter
3 52069315 1 HOUSING, Speedometer Drive Gear
4 56028182 1 O RING
5 56028183 1 SENSOR, Vehicle Speed
6 BOLT, Hex Head, 5/16x18x3/4
018 0077 4 EW0
018 0077 1 EW0 DGP
018 0077 1
7 2892399 1 CLAMP, Speedometer
