Couple of thoughts: Wiring chafed to rear sensor, Front wheel sensor bad (do not know if this would effect speedo). Rear differential tone ring (would require cover removal for inspection). Rear sensor should ohm around 1800, if you have front sensors I believe they ohm around 600. Could be a bad ABS controller but I would start checking sensors, wiring and power to the ABS box before going deeper.
Dave
