2nd Gen Non-Engine/Transmission Spicer part number is:
2nd Gen Non-Engine/Transmission ex-brake Switch
96 4x4, removed the u-joints. Part number on the u-joint itself is
S0570, thats S zero 5 7 zero. That number is on one side and "A5" is labled on the other. Cap Diameter is 1. 35". Cross Dimension, Cap to Cap is 4. 25"
TJM
The number on the u-joint is the casting number. Go to or call your local Spicer distributer and they will be able to look up the right part for you. If you dont know where one is call 1-800-SAY-DANA. Or if you want you can call 1-260-481-3097 which is the Light Axle Technical Service Department and they will be able to help you.
Doug
