The people that talk about street drivability issues don't know what their talking about. No offense intended. Yes. The drivetrain will be turning all the time. This is no different than the 2001 and 2002 non-CAD rams which is a far stronger system. You will probably lose . 5 MPG and a bit more wear(minimal, due to lack of torque applied in 2wd). As SRATH pointed out, you are more likely to break something off road due to the increase in traction. The key words are INCREASE IN TRACTION. You run no less risk with a selectable locker. That is unless you do what SRATH stated and go 1. 5" 35 spline axles. Then you need to change to 35 spline stub axles. The only kits that I know of are the free spin kits. Free spin kit and axle kit run somewhere in the area of $2,500 plus locker and maybe gears at that point. You can break and replace a lot of axles for that much $$$. That being said I plan on doing the free spin kit. That is going to have to wait until my budget allows.
Do yourself a favor and get the Posi-lok vacuum elimination kit. My vacuum accuator sucked up water and I lost front wheel drive. Buy the time I got pulled out, the truck sunk into the Florida Muck. Water then sucked into my transmission pan via a B&M plug kit (garbage). That cost me a transmission.
In conclusion a mini spool is fine as long as you are aware of your axles weaknesses. Your axle in any form is not a MUD BOGGING, ROCK CRAWLING, OR BAJAING axle (unless you do what SRATH prescribed). DON'T put it in 4X4 and make a turn on solid pavement. You will only do that once. A solid spool is a waist of time and $$$. By the time you spend the $$$, you could pay a little more and get a selectable locker. Hope this helps. Good Luck.
'98 2500 4x4, 3. 55, 12v, #6 plate, Banks twin ram, ATS ex manifold, ex brake, 4" ex, ATS 47re, KDP killed, BD steering stablizer, BD 3rd gen adjustable track bar kit, Luke's link joints, Posi lok, Autometer gauges, 2. 5" level kit, Edelbrock shocks, 35" BFG mud KM2.
