Sport Light Conversion revisited......
where can i get sport decals for the hood??
Stull Billet Grille
redneckdr
I did a my canadian truck with DRL's. To find a feed to trigger the relay for High Beams that was not part of the DRL circuit, I went to the DRL module pulled back the rolmex and found a red/grey wire and tapped into it. This wire feeds the highbeam indicator light as well as runs the fog/driver relay so it is pre drl (no reduced voltage/on while headlamp switch is off) my be you could add this to your instructions for others? Not sure if the wire changes colour as with years of truck? cheers
