Squeaky Quad Door
surprise-brake drums not warranteed
What are the side effects of lower stall speed?
My trucks driver side quad door squeaks every time the frame twists a little. It has been doing this since new. If one wheel is going over a bump it squeaks and when going over a bumpy road it is just plain annoying. Has anyone had this problem? Is there an easy way to fix it?
99 24v Quad 4x4, SLT, white, 5spd, 3. 54
LSD, Camel leather(All options except
cab clearance lamps), pyro, boost, fuel pressure guages, Husky
Liners, K&N Air filter, Mopar bed liner,
Mopar molded mud flaps, smitty bilt
stainless nerf bars, auxilliary back up lamps,
Tekonsha Sentinel, DD stage III(m)Injectors,
TST Powermax1, 16cm2 HX40, BD 4" exhaust,
DD extreme duty clutch.
I think most QuadCabs do this, at least both of the ones I've owned squeak. My new truck does it a little on surfaces that are quite uneven. Haven't tried anything to try and correct it though.
One thing I noticed was that unless you give the quad door a little slam, the bottom latch won't lock down completely which will make it looseish and sqeaky. The quad door should be rock solid when latched properly.
Vaughn
2001 Ram 2500 QC SWB 2wd, Patriot Blue/Driftwood, HO Cummins & 6-speed, 3. 54LSD, Cab & Fog lamps, Camper & Tow Pkg.
BOMBings: K&N RE0880, straight piped, debadged body, AutoMeter Sport Comp Boost & Pyro gauges, Amber turn signal conversion
Performance: 245rwHP on BD Dyno, 0-60@ 11. 5 sec 17/22 mpg city/hiway
8990 miles (6/26/00)
I was going to post the same thing ! Even when I "slam" the quad cab door shut, it still seems to squeak when I go over some un-even road terrain. It still seems though after I shut it hard, that the door will still move a little bit around the bottom latch ? maybe something is out of adjustment?
You may try to adjust the bottom striker plate in some and that may help mine also makes some noise a little sun of a gun or other brand of protector on the gaskets will help and extend the life of the gaskets.
