Yes, it's pretty straight forward.
Just for future/historical reference on this subject....
In my case My truck had popped up the DPF full message on the EVIC (has done it once or twice before over the life of the truck) but this time it would not initiate a regen for some reason? Started dinging at me every few minutes that it was full but could not regen?
What I ended up having to do was go into alfa and do a DPF reset to clear it. That cleared all the stored % values as if I had installed a brand new DPF. Then I was able to start the stationary desoot.
I use Torque pro to monitor the DPF % full and see when the normal regens occurred. It is usually pretty linear from the time of a regen to the next as it "fills up" if you will. After resetting the DPF and doing the stationary de-soot, monitoring the DPF percentage as I did before seemed more erratic and not linear? Maybe it was trying to build it's data base again that I had cleared but not sure?
I ended up pulling off the DPF and honestly it didn't look horrible inside but really hard to say if it was clogged in the middle or something?
That one caught me also. I don't know him as he is based on the east coast, but generally the training instructors stay to the script the engineers feed them, and do not have much real world personal experience. They do get to interact with 10 level two and three technicians a day, four days a week, so they receive pretty good feedback.Speaking of regens.
I listened in on an ASE webinar last week on Rams fuel and emissions system. Alot of good info, but one thing really caught my ear. The gentleman claims these trucks are performing an active regen every 300 miles.
Just to Learn More: I understand the need for the "region process". What I need help with is why the tracking and monitoring? I do not have any experience here so I asking just to learn. I have a 16 as well, with 77K and concerned I maybe missing a maintenance step with this process? Any help would be greatly appreciated.
Sorry that is nonsens spoken from that guy, it totally depends how much soot is in the DPF prior to regen.
And as we know the regen happens independent from the filling state of the DPF.
It depends also on the fuel quality, air filter quality and type of engine oil.
So 500 is no more then ballpark, can be 5000 as good as any other number.
*people with non-stock air filters will reach that threshold way faster.
As everything that passes the air filter will be collected in DPF.
From our presenter:
The distance and run time between normal operation of a DPF and active regens will vary depending on many factors.
1. How new is the DPF? The newer the DPF the more area of containment for soot without accumulated ash taking that space. The older the DPF the more frequent regens with less miles or hours between.
2. Fuel usage. The more fuel used the more soot accumulated, less miles between regen.
3. Driving characteristics. Stop and go traffic can accumulate soot quicker than highway miles.
4. Atmospheric conditions. Altitude and temp may also play a small factor with soot accumulation over hours or miles.
The miles or hours between regen will be different between drivers, load, conditions and age of the DPF.
That is much more sensible.
True!And very generic.
how can i tell when it regens, never noticed mine doing it. just looked at its gage and its showing 0 build up. Ive got 12,000 miles on mine.My 19 regens every 24 hours of engine operation. I now have 195 hours/7800ish miles on it, it’s been very predictable.
I can usually tell by the sound of the engine, and then verify by going to the DPF screen. The engine gets a bit more rattle, and makes more intake noise, sort of "intake honk", for lack of a better description.how can i tell when it regens, never noticed mine doing it. just looked at its gage and its showing 0 build up. Ive got 12,000 miles on mine.
You guys are making me want a new truck just so I can play with you all
But seriously, if any of you guys use your Alfa app to do a regen, would it be possible to see some screen shots? Can you monitor DPF delta P while in regeneration?
