Steering Wheel woes:(
Abbott Speedometer Corrector Help
Source of popping finally located...
Hey guys need some advice. Whenever I turn my wheel in either direction it makes a creaking noise. The truck doesnt pull, but its annoying and I dont want it to lead to other problems. Any advice other than taking it to the dealer(its under warranty for the next 30,000 miles)... . thx
Brian
2001. 5 2500 4x4 lwb, forest green, camper group, trailer tow group,travel convenience group, cass/cd/equal, 5spd,slt,LSD,3. 54,Shift-on-the-fly, Line-x bedliner, nerf bars
I LOVE JESUS!!!!
no. but i would like to know what you find out...
2001. 5 2500 4X4, QC, Auto, 3. 54 LSD, SLT, SWB, DD1's, EZ, DTT VB & TC, Westech Boost/EGT gage, Trailer, Camper & Snow plow Packages, White, 35k# Cody Hitch, 20' Gooseneck Lowboy flat-bed Trailer.
1975 Toyota Landcruiser, ARB Air lockers Front & rear, 400 Small Block, SM420 4spd, Stock LC transfer case with 2 or 4 high and 2 or 4 wheel drive Low gears, 15. 5x36" Radial swamper on 12" rims, Custom front & rear bumpers, Roll Cage, Warn 8274 8000# winch, 2. 5" spring lift, 2" body lift. Premier on-board power welder, on-board air, 4-wheel power disk breaks, power steering, Lot of fun.
SA Law. When my 98 did that, it was the top universal on the steering shaft just below the master cylinder. Lube with WD 40 or similar. Also, there is a boot on the shaft. Squeeze the lower part of the boot to force the shaft grease back into the sliding shaft area. If the grease has pushed out, you may get a slight popping sound. Hope this helps. BTW mine would mainly squeak when staying in a long curve.
2001 HO 6 spd 2500, 4. 10 LSD, Towing Package, Electric Brakes, SPA EGT/Boost Gauges, Fog Lights, Real Backup Lights, Molded Running Boards, Lucerix X Mount Heated/Power Mirrors
