Lower the steering wheel to it's lowest position and then pry off the instrument panel bezel (either black or wood trim depending on your truck). Pry it out evenly or you'll break some of the plastic tips.
After the bezel is removed you'll see the radio is held on to the dash with 2 or 4 7mm bolts . Disconect the wiring plugs and antenna and your done.
Jon
