Still need some help w/hx35 install
Just got the new truck
Got My EZ on Today...Cool
My 98. 5 HX35 will be here today and still need some help! IS THIS A STRAIT BOLT ON REPLACEMENT FOR MY HY35? AS I DONT HAVE A MANUAL YET DOES ANYBODY HAVE TORQUE SPECS FOR THIS JOB? I AM FAIRLY MECHANICALLY INCLINED, I WOULD APPRECIATE SOMEONE WALKING ME THRU THIS SWAP BUT I AM APREHENSIVE TO DO THIS. AM I BITEING OFF MORE THAN I CAN CHEW AND SHOULD I TAKE THIS TO MY MECHANIC(CUMMINS EXPERT)AM I BEING WIMPY? OR TOO CAUTIOUS PLEEEEEEEAAAAAAAASSSSSSSSSEEEE HELP
ME I DONT WANT TO MESS UP MY 38,000 BLUE BEAST(BABY)
01 qdcab 4X4 sb at DTT TC & VB sport Intense Blue stockland shell and carpet kit Rancho 2in prototype lift kit 315/75r/16 BFG AT ko centerline thruster 16X9. 5 VA DB stg II inj BD 4" exh hy35 pillar pyro 28ft Desert Storm toy box Honda 4-trax 300R 55hp @ rear wheels on race gas
Call Jeff Garmon Jeff can do the swap with his eyes shut
Call 1-800-608-3888
Jeff is located in Georgia so call accordingly #ad
Jeff is a super guy
It's really not that hard--just remove and reverse install--take your time--I was nervous to, but finally just went for it--make sure you have a new gasket for the oil return(on the bottom of the turbo) and an exhaust gasket--oil the turbo---just get the bolt good and tight for now and if I get a little more time I'll tell ya what my torque specs were for a 99---go for it---chris
here is the installation checklist for the HX35/40
1. always understand why the original turbo needs changed before fitting a new one.
2. check the turbo dataplate to ensure the part no. is correct for the engine/application
3. check that the engine intake and exhaust systems are clean of obstructions i. e. oil, gasket debris.
4. replace the oil and air filters using those recommended by the engine manufaturer.
5. change the engine oil using the type recomended b its manufacturer
6. check that the turbo oil inlet and drain connections are clean and free of dust and from obstructions and will not leak under pressure.
7. mount the turbo on the exhaust flange and check that the turbine inlet gsket fits properly without obstructing the gas passages.
8. rotate the turbo central bearing housin so that the oil inlet and drain are in the vertical position. up to 22 degrees fro vertical is permitted
9. pour clean oil into the oil inlet hole and then twist the rotor assembly until clean oil starts to flow out the drain flange.
10. rotate the compressor housing into the correct position and assemble the the air intake and boost outlet connections. check the the connections are well made and do not have a possibility of leaking under pressure.
11. reassemble the exhuast system to the turbo housing inlet. check that the connection is well made and will not leak.
12. skip
13. check all hose/pipe clamps/studs/nuts are correctly torqued Note:cannot locate torque settings at this time.
14. carefully assemeble the tur oil inlet pipe and check that the connection is clean and will not leak under pressure
15. cranl the engine DO NOT ALLOW TO START until oil flows out the turbo drain flange.
16. assemble the oil drain pipe and check that all connections are clean and well made without obstruction
17. skip
18. start the engine and leave running at idle for 1 minute so that the oil supply system is fully perational.
19. accelerate the egineand check for any leaks of air/oil/gasses under pressure
20. recheck all hoses and clamps for loose connections
Enjoy.
from what i have found both from my Holset and Dodge manuals their arent any torque specs avialable to go by. and the most important step is to preoil it by filling it and spinning the turbo until oil comes out the drain flange.
Todd,
2001 Q-cab SB 4x4 5spd 3. 55's, A pillar Boost/EGT,4" turboback exhaust,custom built aluminum airbox W/K&N-RE0860 through the cowl, and more to come...
Thanks Todd very helpful info let me know if i can help you with anything in relation to my signature/mods
Thanks, Todd! Perfect timing, since my HX-40 goes on tomorrow morning.
Rob
2001. 5 RAM 3500 QC 4x4 ETH/DEE Silver/Agate, 4. 10, USGear OD, Rickson 19. 5 Wheels, DD EZ, DD3 Injectors, SPA Guages, Psychotty, Firestone Airbags, Hellwig Rear Swaybar, Torklift Superhitch & Camper Tiedowns, Mag-Hytec Diff Cover, DD 4" Exhaust, US Gear Exhaust Brake, etc. On order: Southbend Clutch, HX-40
