You can get some improvement by adjusting the pump with stock injectors, but it does put an increasing strain on it the further you go.
Up-rated injectors allow the pump to do the same or less work and make more HP/torque.
A good place to start if you want fairly clean power is the 180HP injectors.
Talk to Piers or Joe D. for sourcing them. The next step up is the POD's (Lucas). For our trucks these babies are like shower nozzles. They make good HP, higher EGT's (depending on pump settings) and MORE smoke.
Either way, your pump timing should also be adjusted a bit from stock settings to help work in conjunction with those injectors.
Oh ya, be sure to put in some basic gauges too. . EGT, boost are good starters.
Good luck... Bob
