i put the cross over on and no diff. the pass side battery is getting warm after 4 min. of run time.could the test the store did be faulty?
almost 16 volts. its an old volt meter, not digital
this is where it gets odd. the driver battery is showing 12volts, but the cross over shows 16volts
is the voltage regulator in the alt or external.volts is 16 maybe20? right side bat is over charging big time.
new batteries and new cable. where is the ecm ground. thanks k
both batteries tested good. how can the alternator put out 20 volts or more,and the ecm is good?
