Stratus drain plug problem
Bad Day at Diablo (long)
HEYBOSS is turning 40
Fellas,
I need a little advice. What do you recommend I do about a leaky drain plug in my Stratus. The mechanic at the dealer re-tapped the the hole, and put new plug in, but it still has a tiny leak.
Any suggestions greatly appreciated.
Big A
Try putting a gasket made of rubber or cork between the factory washer and the pan. This worked for my truck when the sealing surface was distorted due to excess torque.
Bob
leaky plug
;) If I had that problem bud, I would look for a quick drain method type fixture so i wouldn't have to keep removing that plug that has already been compromised. I would then seal the treads of the unit with Leak Lock which is used in refrigeration threads. Should end the worry! Tim
Usually rather than tapping out the pan to a larger size most guys will use a self-tapping oversize plug, I'll bet that's what your tech used too. These tend to leak but can usually be fixed by using a non-tapping plug with the correct threads for the new oversize hole.
