Streering Stabilizers
fender mount cb antenna
arm rests
HOWDY ALL. .
Been trying to find "DUAL STEERING STABILIZERS" For my 98. . :confused:
I cann't seem to find any for a 2500??
Any one know who makes one??
THANKS.....
Mike In Maine
Try Jackit.com they sell the one mentioned above for around $80. Phone number is 1-888-452-2548. Part number should be SKJ 7218, that is for 1998-2001 1/2,3/4,1ton 4x4 PU. If you have the heavy duty military style front housing you might have to get bigger U bolts, thats is the only change to the kit required. I have used them many times fast and friendly, and usually in stock. Later good luck.
See rig pics to see what it looks like, later.
If not I got the kit at 4Wheel Parts, wrong one for my truck though, seems the tie rods are different for pre 98s so the "end to end" dual stabilizers didn't work, I had to get the "stacked" set up.
Look around, any advertised truck or 4-Wheel center will be able to help you. Also Summit Racing and Jeggs have 4x4 parts, both are great to work with. 4-Wheel Parts is a huge store that carries a large inventory of all the latest and most popular brands, NTW or Nation Tire and Wheel is another source for parts.
For your truck, they make both single and dual steering stailizers, and in the dual type there is the stacked or in-line type. I went with the in-line type myself not long ago, it works great and looks good doing it.
I have the set Y-not has on my 2002.
I have the oversize militry axles, and had to use larger u-bolts.
Works great,
Wiredawg
