mfunderburgh said:A stock turbo class or 2. 5 charger class will require +500 to win it plus a decent truck setup. I think the work stock DHRA class will need to be pushing towards the 550 mark to be in the top. DHRA street class i'd say at least 650-700. Matt
fest3er said:In my humble opinion, I think Work Stock will range up to 475. Street Diesel will range up to 550-650 and Super Street will range up to 800-1000. Modified will range from 1400-1900.
N
jwilliams3 said:Its gonna be hard to beat the Duramax trucks in the Work-Stock class.
SLangegger said:In work stock class they cant do ANY mods to the front suspension?
(I. E. tierod sleeves, strapping the front)
TCluff said:I GUESS YOUR RIGHT, YOU ARE GOING TO BE DODGING A LOT OF BROKEN PARTS IN THE TRACK, MAYBE ITS JUST ME, BUT A DMAX HAS TO HAVE SOME GOOD FRONT SUSP AND STEERING WORK TO USE ALL THAT POWER!!!!!!!!!![]()
mfunderburgh said:It must just be you, $140 dollar tierod sleeves and a $5 set of 1inch rachet straps isn't what i call a lot of steering and suspension work.
TCluff said:I HAVE ONLY PULLED WITH 6 DMAX TRUCKS, ONE BEING A 2005 SEMA TRUCK THAT PULLED 70 FT AND SPIT THE FRONT END OUT, ONE WAS 604 H. P. THAT ONLY PULLED 170 FT AND LOOKED LIKE THE TRUCK WAS GOING TO FALL APART, THE OTHERS ALLISON COULDNT FIND A GEAR, TAKE OFF HARD, GET INTO TROUBLE, THEN DOWN SHIFT TO MANY GEARS AND ALMOST GET REAR ENDED BY THE SLED, SO NO, I DONT THINK DMAX TRUCKS PULL VERY GOOD UNLESS THEY HAVE EXTENSIVE STEERING AND SUSP WORK SO THE FRONT END DOESNT TRY TO DRIVE OUT FROM UNDER THE TRUCK, LOOKS LIKE THE TIRES POINT AT EACH OTHER, DRAG RACING YES, SLED PULLING NO JUST MY OPINION, NOT A ******* MATCH!!!!!!!!!!!!!!!!!!!!!![]()
