I've had the same problem happen twice in 3 weeks, here goes- 3 weeks ago these problems all started in one day-squeek, squeek noise coming from front passenger wheel, when braking the truck would pull to the left, brake pedal would fade, and finally when making right turns there was a clunk. I jacked up the truck and found that the passenger side wheel was wobbling on the stub shaft, the castle nut had destroyed the cotter key and "moved" up the shaft, stripping the threads. So, we took the truck back to a shop that did my ball joints last year thinking they had stripped the nut reinstalling it, they replaced the stub shaft, I got a new nu from Mopar4less
, and completed the fix last friday. This past friday, on my way home from work, same symptoms all come back, this morning I jacked the truck back up, and the same thing happened!!! Everything is messed up again! So now I need to replace the same parts, but I need to find out what caused this otherwise I'll be doing it again next week. Could a bad or warped rotor be the culprit? I noticed a slight "shink" like sound coming from the wheel when driving home Thursday, if that helps. Any info will be greatly appreciated, thank you...
