Ozymandias
It's generally wise to work with metrics wrenches on a metric vehicle.
It comes right back to being PLASTIC, give it every chance to come loose without stripping that PLASTIC nut off . Let's give everyone that reads this , this advice especially the newbies , if you are buying a socket get the 28mm , why mess with 1*1/8" when the better socket is 28mm.
So is there any reason NOT to put light coat of vaseline on the cap threads ??![]()
I would think silicone (dialectric) grease would be a better option.So is there any reason NOT to put light coat of vaseline on the cap threads ??![]()
I've used motor oil on mine since 2000 and no problems. I still have a new 2nd gen filter canister cap I never needed. Just did the 45K mile service on my '17 5500 oiled all fuel filter and oil filter gaskets.
Oiled the threads and gasket?
I’ve never oiled the threads, just the gaskets.
AKA as the "RAM Gorilla" who installs oil filters, and his duties were expanded to front fuel filter at some point.It's been my experience the first oil filter and fuel filters change are the most difficult to remove. The factory really puts stuff on tight. None of the subsequent ones are nearly as hard to break loose, regardless of the amount of time between service.
NO OEM oil filter has ever vibrated loose.
