As somewhat mentioned.... proper 6 point 28mm socket, constant pressure from a long extension with a break bar...someone with a pipe on one of the teeth on the top of the cap and tap the pipe gently with a hammer while apply the pressure to the nut. Also, a careful relief cut or two...on the end of the cap to relief pressure might be the end game, if the above doesn't work. I would not cut through and get debris in that canaster.
I found slow and steady pressure is required to get that cap loose, if tight.
