Stuck in four wheel low
6.7L MBRP 5 inch Today
Urea/regen?
Okay guys here is what happened, was unloading the truck camper, put it in four wheel low as there is not much room with the hips. Pull out and I notice a CEL and it is stuck in four wheel low. #@$%! the four wheel low is flashing on the dash and turning the dash switch does nothing. #@$%! If you change it to four wheel high the four wheel low just keeps flashing, same with two wheel drive. #@$%! Oh for the lever on the floor.
you need to be in neutral pretty much at a stop (less than 2 mph), for it to go into and out of 4low. otherwise it wont engage and it flashes, cause its waiting on you.
Thanks, I tried the neutral thing and it worked on the second try. I guess that I am just too use to pushing in the clutch and moving a floor mounted shifter. This truck is going to be a learning experience for this old guy.
The floor mount shifter is definitely better, but they're harder to find. If I had it to do over again, I'd get a floor shift, manual transmission 3500 instead of the flip-switch auto 2500.
