So, when maitaining my truck I'm pretty meticulous about torqueing things properly. Some might say too much so (I have steel wheels and use a torque wrench on the lugnuts). So, the service maunal says the oil drain plug is supposed to be torqued to 60 ft-lbs, I always thought that seemed really high, but looking at the crush seal design I figured it was probably correct. So, I was doing an oil-change on the truck today, running the plug back in and put the torque wrench on it, it didn't get to the proper torque and gave a little pop that just didn't feel good. Holy Cow, at about 20ft-lbs the flange broke clean off the drain plug. Had to call Dodge and luckily they had one in stock, $8 for the plug and another $8 for the seal. Well, now I'm gun-shy of breaking another one, so I only torqued it to 40 ft-lbs, that should hold a frikkin' drain plug in, huh? Those of you that still have a factory drain plug, what do you all do, hit it with the 60 ft-lbs, or just crank it nice and tight?
