To start off with here is a little bit of background
on this conversion. The Suburban is a 95 6. 5 liter 4x4
diesel with a 4l80E auto transmission. The 6. 5 runs great
and the transmission was recently overhauled. The problem
is me, I want a Cummins so the 6. 5 is going. I have
purchased a 91 intercooled Cummins with 133k miles.
It was someones project motor and they had an 01 auto
transmission built to go behind it using parts from a
96 transmission so it doesn't require electronics. The guy
I got it from ended up buying a p-pumped motor and an
NV4500 so I bought his motor and transmission. I have also
purchased an HX35 Turbo. I plan on driving the rig as a daily commuter for the most part pulling small trailers, boats, etc. . most of the time with some heavy loads on occasion. I plan on turning up the pump, large exhaust, intake. Now I have numerous
questions before I get started on this install. Here
they are:
1) What should I do for an intercooler? Guys are mounting them under the bumper but it doesn't seem safe what else can I do?
2) Should I invest in aftermarket injectors? What will they do to fuel mileage? I want power and drivability with mileage. Is that possible?
3) What is a reasonable HP and torque level for this conversion? Is 300hp out of the question?
4) Wiring diagrams, are they available?
5) Do i need to do anything to my transmission or is it going to hold this power? It is rebuilt like I said above but while it's out should I buy a torque converter, Transgo. ???, to make sure it lives, or is stock good enough?
6) My truck has 4 10 gears. I am concerned they are too low. Should I change them out or add a gear vendor or something? I would love to be 2000 RPM at 75.
7) Is there something I've overlooked?
they are:
