I have a 95 model that has suddenly lost power. I have checked the usual things ,like the fuel and air filter and replaced them. That did'nt help. I checked the hose out of the turbo to see if any oil was in there and I used two fingers and checked the turbo bearing , both seemed to be good. It starts the same as usual, so I don't think that the pump timing has moved. The truck doesn't have any guages on it or I would check the boost, but going by the visual on the turbo I think the boost is ok. When I rev it in neutral the engine stumbles on the top end and sort of skips or misses. Does these engines have a transfer pump? Could it be bad and causing the symtoms? Is there any other filter in the Bosch pump that could be partially plugged? Any ides will be appreciated!!!!!
95 2500 no mods except straight piped an no no-sing ring
