I've have a 96 CTD 5-speed and just started having this problem, It will run fine until it gets warmed up and going down the road it starts to surge and run wild, and when you come up to a stop sign it will die. It will make a ticking or clicking noise when it starts to act up. When it dies it will start right back up and if you step on the pedal it will rev to 3400rpm instantly and slowly dies. The first time it happened i just made it home and i changed the fuel filter and it ran fine for 3 weeks. Drove it 1000 miles with no problem. Today on the way home from work it started all over again. Do you guys think it could be the fuel filter again, a bad pickup tube in the tank, or the rubber return line, or the rubber elbow line on the lift pump, or a bad lift pump? I buy my fuel from the same place all of the time. I always add some power service with cetane booster at every fill up. Is there any way to install a fuel pressure gauge to check it? I really like all of the great responses!!!!
