What effect will adding about 225 pounds of winch and bumper have on the stock springs of my 08' 2500? Do I need to order new coils to go with the added weight? Any first hand knowledge would be helpful.
I added a Trailready front bumper with a 15,000 lb milemaker hydraulic winch to my 2006 2500 CTD, didn't do anything to the front suspension, haven't had any front end issues.
That's amazing in that just adding a popup camper to mine made it bottom out @ 15 mph on surface streets. My front axle load is 4400# which is probably in line with your QCSB's additional weight stock. Adding that nice Trailready bumper and winch would render a lot of leverage over your frontend.I added a Trailready front bumper with a 15,000 lb milemaker hydraulic winch to my 2006 2500 CTD, didn't do anything to the front suspension, haven't had any front end issues.
You'll like those springs. I needed a bit more lift and sold mine to a guy on the east coast with a snowplow. He's pleased.I haven't experienced the wandering you speak of, But I am adding new coils and shocks from Lorenz. I am installing basically the same package except I went with the Warn powerplant 12K.
Buckstop has a long lead time so I think I'll be able to get the springs and shocks done prior to mounting the winch.
Have you noticed any significant blockage of air to the intercooler? Since I ordered my bumper unpainted I was thinking of adding a duct or perhaps two to direct air where it needs to be.
My front end weight ranges from 4400-5400 depending on loading, winch installed, etc.. The normal weight is around 5040. To be honest I don't notice much at the top end of the weight, but I do at the bottom end (guessing a QC LB has a stiffer spring than a RC LB). I do tend to pay too much attention to the happenings in my truck.
The Bilstein shock I installed last year made a huge improvement in ride quality, thou bottoming out was never really an issue as I have always ran a level kit, 2" for the first 4 years and a 1" since.
My biggest concern about the weight would be accelerated wear or OE ball joints and wheel bearings.
My biggest concern about the weight would be accelerated wear or OE balljoints and wheel bearings.
You might want to rethink your bumper choice,I am sure Creative Fabworks could build you a better lighter winch bumper.http://creativefabworks.com/
That is the consensus of every suspension seller and quite a few bumper sellers. They won't say that outright but pressed they will acknoledge they see accelrated wear with the heavy bumpers. The rougher the roads and the more time spent on them the faster the failure. Pretty pushes the need for better quality BJ's to the forefront every time.
Jus tputting the bumper on and not driving many miles on smooth roads will not show the issues. Use them har dand it will show.
