Swap stock 3.73 for 3.42
OBD II Code Help!!
dual mass flywheel??? or double disc clutch?
Thinking about doing this on sig truck for fuel savings and better cruising RPMs. Probably looking at a couple grand. Is it worth it?
All I can say is that I absolutely love my 3. 42 ratio on my truck, but I bought it that way from stock. Whether its worth it to you or not is something only you can answer.
Below are the speed / RPM / gear combos I'm in:
This is on a stock setup, so tires are the stock 32" or whatever the on/off-road tires are from the factory on the 08s. Hope it helps.
Speed (In MPH) -- Gear -- RPM -- Speed (In KMH)
5 1st (L) 1250 8
10 1st (L) 2250 16
10 2nd 1300 16
15 2nd 1900 24
20 3rd 1500 32
30 4th 1550 48
40 4th 1900 64
40 5th 1480 64
50 5th 1850 80
55 5th 2050 88
50 6th 1400 80
55 6th 1550 88
60 6th 1690 96
65 6th 1800 104
70 6th 1950 112
I've been thinking about doing the swap... but at $1800-2000 its a bit pricey and I'm having to think about it a bit harder then some other mods.
