Swaping HY35 to HX35 need help
No Power on hills
Overweight RAM 2500
I replaced mine on a 01 and it was with a 00 no problem was very straight forward and everything fit perfect. I bought the new gasket for the exhaust to turbo and the one for the oil return. Takes about an hour the first time. The rear lower left exhaust bolt was the hardest one because it is hard to get leverage on. By the way don't forget to tighten the oil line to the turbo. I drove mine about 20 miles and wondered if I tightened it . Didn't but had no leak real lucky
OK... ... . So it's a bolt on... . What kind of changes are you gus getting from the HX over the HY? Is the 12cm housing putting out more volumne than the puny HY 9cm?... I would think the pressure would be the same... Lower EGT's? What? WHAT? Is it cost effective, since there seem to be a big diff in price between HX35 V HX40?
2001 Quad,4x4,AT,4. 10LS,LB,Loaded enough,stock,mostly... . 65 Chevelle sedan, Hella nice driver, 53 Nash Rambler Convt,1 of 653 built,[not a Metro], GM drivetrain, injection, and auto/od
Specialized FSR PRO Stumpjumper,Cannondale F2000, Loaded
MTD Lawn tractor with flames
12' fishin' boat, loaded. .
Got a nice deal on HX35 (thanks wileyslover)
need help making the swap
Are there any differences in these turbo's
in relation to there hookup or mounting? as i have heard that there might be problems in connecting the bottom oil drain back to the block. the HX35 came off a 98. 5
Can anyone make any recommendations for the swap?
Should i go with the 14cm housing over the 12cm as egt's are my primary concern
Thanks all for your expertise.
Sorry forgot to show my profile(Brag list)
01 qdcab 4X4 sb at DTT TC & VB sport Intense Blue stockland shell and carpet kit Rancho 2in prototype lift kit 315/75r/16 BFG AT ko centerline thruster 16X9. 5 VA DB stg II inj BD 4" exh hy35 pillar pyro 28ft Desert Storm toy box Honda 4-trax 300R 55hp @ rear wheels on race gas
Scott,
Thats funny!!!!
Havn't put it on yet because I have some warranty issues to work out... Can't take the truck in yet because of the check engine light problem... It seems all the CA trucks that have a DTT TC, lite up the dash MIL. , so until Bill K. can fix this, I can't take it to the dealer... . Just hobblin' along for now. .
Colin
