Engine/Transmission (1998.5 - 2002) Swapped Manual for Auto, Now truck surges when put in gear, ECM Problem ?
2nd Gen Non-Engine/Transmission What year rims fit? 1994 2500
2nd Gen Non-Engine/Transmission Headlight covers/protectors
4wheelsmoking,
I would be interested in what kind of allison would fit behind a 5. 9 without major modification of the bell housing. I have a 97 fiver. Any information you want to share, Please PM me. Thanks
WD
Destroked said soon he will have an adapter that will allow the Allison to work with OUR transfer cases. right now you would have to use a GM transfer case like a Duramax.
Rick
And the result is ?
It works... no romp, romp and cruise control works too. The only thing I noticed was that cruise control didn't want to set between 35-40 mph. It would act like it was trying to set then kick off. I could set it at 40 mph and then decrease it down to 35 mph without a problem.
Now the bad news. I'm way down on power and I'm setting an over boost code (P0234) and a P1694 (not sure what this is) and of course the standard P1693. So it looks like I have stock software, not the CaTCHER. I'll send a message to Marco tonight. It was probably a miscommunication on my part.
Dave
Party -
What ever happened? Did you change your APPS when you changed trannies?
As I understand it, the APPS for the auto vs standard are slightly different.
Nope, did not do anything. I swapped the transmission again and put in a looser torque converter. That made no difference. It's annoying but not that bad. I wonder how changing the apps would affect it. ?
