and the reason for the limits are because its a synthetic oil trying to make old and out dated petrolium standards,(chemical and mineral) thats why almost all sythetic products are a blend!!!! belive me that is a deep and long subject!! :-laf
WNowlan said:ZDDP is not a bad thing. It just causes our catalytic converters to fail over time. It has been the best antiwear additive for years.
Diesel Power said:your oppinon is not much without proveing it, do you know how many other api approved oils have the same amount or more ZDDP? answer--alot!! look in to it. red line, royal purple, moblile one castrol syntec all have that stuff in it!!![]()
Diesel Power said:and the reason for the limits are because its a synthetic oil trying to make old and out dated petrolium standards,(chemical and mineral) thats why almost all sythetic products are a blend!!!! belive me that is a deep and long subject!! :-laf
pwr2tow said:Oh, I beleave in synthetics but what I really want to know is this.
I have the 2005 in my signature and it has a 7/70,000 and 7/100,000 warranty. If I was using a none API certified fluid in the transmission, transfer case, front and rear axles and at 50,000 miles one of the formentioned parts has a failure and DC decides to void my warranty because I did not use an API certified oil. Will the amsoil stand by me and help fight DC or will they stand behind me with their thumb up their (you fill in the rest)?
Thank you for your time.
john3976 said:Royal Purple is a full synthetic oil and it meets API certification.
You are an Amsoil dealer I bet, you are pulling out all the old time honored Amsoil spoofs.
Diesel Power said:the truth be told, not 1 of royal purples oils are 100% synthetic they are a strong blend, that came straight from RR!! i also sell RR, i am just comparing and contrasting. also if it does not say 100% syn its not 100% syn, amsoil and redline are the only syn oil's that i know of that are 100% pure!!! :-laf
pwr2tow said:Wayne,
Please do not insult my intelligence my brushing me off. I know all about the different licensing standards.
You did not answer any of my questions directly, instead you chose to give information that anyone can look up on the internet and is pretty much irrelivent to my questions.
Please take my questions as being serious. I truely am looking for a lower cost alternative to the dealerships monopoly type high cost prices they charge for their products. I just do not want to loose my warranty. If amsoil products will not keep my truck in compliance with warranty standards set forth by DC then just tell me they won't. I'am referring to drivetrain components not engine oil. I already know where to get low cost engine oil that will let my trucks engine go to 1,000,000 plus miles.
I could care less if an oil is certified or not as long as the company will do everything it can including going to court on my behalf to help me if a vehicle manufacturer denys me warranty.
john3976 said:Just a quick internet search revealed:
Chevron Supreme 100%
Valvoline Synpower 100%
Texaco Havoline 100%
John Deere 100%
Nissan FasFlo 100%
Phillips Tropartic 100%
and the quick kicker Synlube 100%
Synlube says Amsoil was not first in Synthetics see web page:
http://www.synlube.com/synthetic.htm
The list goes on.![]()
pwr2tow said:I know what your saying and that's exactly why I'am skeptical about using a product that does not fall exactly within a vehicle manufacturers fluid specifications. The vehicle manufacturer claims the failure one way and the oil supplier claims the failure another way. The owner is the one who in the end ultimatly pays. If the fluid falls exactly within vehicle manufactures specification then they can not deny warranty, the reason API licensing for motor oils.
I guess instead of all my delicate questions I should have just asked.
1. Does amsoil gear oil meet DC's fluid specifications exactly for AAM axles? Which one?
2. Does amsoil MTF meet DC's fluid specifications exactly for the NV5600?
If they exceed specifications that's all the better.
Thank you
pwr2tow said:If the fluid falls exactly within vehicle manufactures specification then they can not deny warranty, the reason API licensing for motor oils.
1. Does amsoil gear oil meet DC's fluid specifications exactly for AAM axles? Which fluid?
Thank you
