The truck is a 94' 5-speed with only 76k miles on it. . problem is, 3rd gear makes some noise almost like bad syncros after the clutch is disengaged and you are rolling {below 1500 rpm} then goes away. The question is will fully synthetic oil help these grunts and groans out? or should i just change with regular oil. . and what weight oil does it take, thanks!
