Are the gains from synthetic worth the extra cost? Does anyone know how much hp one would expect to gain by changing? Finally what weight is everyone running? I want to run Mobile One any thoughts?
... I've heard of guys gaining 2 mpg just from the switch, but I don't believe it...
I don't beleave any of the claims made by any synthetic oil producer except cold weather flow characteristics. Why? Simply because in the 48 years of my life I've never seen any of their claims come true.
Yes, I've used synthetics in many different applications both gas and diesels over various vehicles and years but always go back to regular oils. Why? The synthetics never performed any better than regular oils and hardly no one keeps their vehicles long enough to warrant the extra cost.
If you really look at the whole picture and trade vehicles every 3-5 years and put on 50,000-75,000 miles why even change oil. Change the oil filter every 6 months add back the quart or so of fresh oil and let the next owner worry about it. :-laf
I certainly wouldn't want to buy a vehicle from you, if you do that kind of maintenance!![]()
Didn't say I did that kind of maintenance, wayne you of all people should know how anal I am about my vehicles and maintenance. We've had these oil related discusssions before.![]()
The benefits of synthetic lubes are many. Superior wear protection, increased horsepower, cooler running engines, reduced deposits, reduced oil consumption, resistance to oxidation and breakdown, easier winter starts - they all add up to a better running, longer lasting vehicle.
Synthetic oils are frequently made from higly refined petroleum base stocks (VHVI and XHVI hydrocracked oils). So, the fully synthetic or 100% synthetic oils are very rare. In fact, most of the synthetic oils are petroleum based (mineral) oils.
As to the Viscosity (weight as you state) most Diesel engines should use 15W-40 for most temperatures. However, the SAE 30 grades are gaining in popularity, and will provide better fuel economy.
What HP gains? There have been studies that show an increase in HP, but generaly speaking, your not going to feel a lot of HP gain, but you will feel a smoother running Engine.![]()
Wayne
Doesn't anybody read owner's manuals anymore?
It recommends 5W-40, not 15W-40 synthetic. It has to do with cold start thickness. That's the only way to save $$$ with synthetic. Better cold mileage. These engines take about 10 miles to warm up, so cold mileage matters to all but longhaul drivers. Why do they even make 15W-40 synthetic? I think Amsoil is the only one with that, and that's one way to waste money. Mineral oil cannot be made 5W-40 because it would take excessive additives, and you would need to start out with 5 weight, rather than 10 weight, and it would cause excessive deposits in the engine as the additive breaks down. Synthetic does not need those additives, so it does not break down, staying cleaner.
The best benefit to synthetic oils vs. dyno oil is extended oil drain intervals and better wear protection. You will make the expense diference up in less oil changes and lower maintenance costs. I run AMSOIL Series 3000 Synthetic 5W-30 Heavy-Duty Diesel Oil and have had great results. AMSOIL now makes a great CJ-4. good luck
I don't believe any of your claims about what your product will do and neither does my Dodge dealer. I'll stay with Delo400.
