Hi groundpounder
I've got a "93 with 126k on it and have used Amsoil 15W40 Marine full synthetic diesel since my 2nd oil change. I do an analysis at each oil change I also change oil every 6,000 miles. I have never used even 1 quart of oil between changes nor have I had a bad analysis. I also use Fleetguard oil filters. When I switched over I didn't do anything special and have never had any problems. The synthetic will clean everything up by the time you do your second oil change. You may see some oil useage between the first and second change but it should return to normal after the second synthetic change. The filter you are planning to use is the recomended filter to use with synthetic on the 24V engine. Good Luck
Happy Trails
1993 250 4X2 - Banks Power Pack, BD Power Injectors, K&N Air Filter, 6 gauges and tweaked pump. 27lbs boost unloaded.
Horton fan & NV4500 5 speed.
