T-51 service wish me luck
Adding tow mirrors to 2500?
Axle and transfer case service
Being the nice guy I am, I am dropping mine this afternoon so it's cold in the am for them to start right away.
They are replacing a plastic pad on my running board that developed a chip under warranty.
My rubber donut around inside fan shroud never sealed properly at the bottom replacing under Warranty.
Water pump replacing under warranty. Giving me an extra gallon to top off with since I am heading to Pahrump next day.
Emissions Cat or what ever it's called replacing under warranty.
Adjust hill start under warranty.
Check to see if I need Trans Interlock fixed or not under warranty.
I figured why not save em up!!!
Good luck.
I keep sticking with the same dealer, so far the first 5 recalls have went well with them. Hopefully no problems with the water pump recall, hope it goes well, no reason to believe it won't.
I had the T51 and T05 both took care of a few weeks ago with no issues, it took about 4 hours for both to be taken care of.
T51 waterpump and T79 shift lock both done today.
In and out in 2 hrs. Tech said it takes longer to burp it then to change the pump.
