T76
Dana 80 ?
Htt Exhuast Manifold
what I have is a GT42R ballbearing which people tell me is the same as a T76
turbonetics ,all I wantr is to know if it would work on a street class puller with a very loose converter.
Specs that I know:
94mm inducer
meets 2. 8 rule
1. 15 exhaust housing
If it's equaly to a GT42R, then it won't be too bad at all. For sled pulling and a 2,200 stall converter it will work like a Champ!
With a Comp, Mach 4. 6's and a 42R, friend of mine put down over 550 (IIRC 580) RWHP, and ~8xx rwtq.
Driveability was descent, but not wonderfull. I wouldn't be afraid to put it on a street/strip truck (more strip than street).
Merrick
Specs that I know:
94mm inducer
meets 2. 8 rule
There are two versions of the GT42
Only one meets the 2. 8 rule. It is the GT4294R the 94 is the exducer not the inducer. It is actually smaller than a T76. The T76 does not meet the 2. 8 rule. Obviously... it has a 76mm inducer
Air flow for the GT4294R is 85 pounds per minute or, 1130 CFM
Air flow for the T76 is 91 pounds per minute or 1210 CFM
This is why I love the Cummins guys , you all are so smart. Thanks very much ,
One last thing so according to that turbo chart floating around here a HX55 would also be about the same as a GT4294R (as in flow #'s). so it is just a little bigger than my JR lil55 ? Sorry for being so turbo stupid.
Good Question. According to Holset the HX55 is good for . 75 kg/s or 99 pounds per minute or 1316 CFM.
I kinda doubt with flow numbers like this it will meet the 2. 8 rule.
