I took my p7100-911 pump apart last week. There is absolutely no way that I could see to hurt the pump in any way by removing the plate. The rack looks like a piece of angle iron with notches in it. With no plate, it bottoms out on the stop plug at the front of the pump. There is no weak little pin that will break. There is a pin on the back of the rack in the govenor housing. It is pushed by an arm from the shutoff solenoid to move the rack all the way back when you turn off the key. It kind of looks like it is stopping the rack IF YOU TAKE THE PLUG OUT. Even then this is still not the case and you can slide that arm out of the way to prove it. Even if the rack was stopped by that "little" pin, there is NO WAY you could ever put enough force on that pin to break it.
Now all you plate-vending people try to prove me wrong.
