I'm sure that some of you will have some good advise on my problem. As you can see by my signature, I've tried to properly set up my truck to pull my 10k fiver. The valve body was the last item to be installed. Prior to that install, I was getting T. C. slippage under heavy load (which I avoided). Since adding the V. B. , on start-up I shift into any gear and about a third of the time its like its in neutral. Then I rev up to about 1100 rpm and let off and then the power gets to the wheels. Also sometimes, I stop , like at a city stop sign, and when it's go time it's like the results on start-up. The transmission check out OK for T. C. clutch debris when the V. B. was installed. What's going on
