TDR Issue 79 - February/March/April 2013
TDR Issue 78 - November/December/January 2012-2013
TDR Issue 81 - August/September/October 2013
TDRadmin
Staff Member
[RAW]/articlelive/content_images/TDRCover79.jpg#ad
<table style="HEIGHT:101px;COLOR:rgb(0,0,0)" border="0" cellpadding="4" cellspacing="8">
<tbody>
<tr align="left">
<td style="VERTICAL-ALIGN:top">
<font face="Arial, Helvetica, sans-serif" size="2"><span style="FONT-WEIGHT:bold">ARTICLES | Sold Out</span></font></td>
</tr>
<tr>
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">10 Back</span><br/>Issue 39 Review - The Eight P's of Diesel Power </span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt">• Mixing Gasoline with Diesel </span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt">• Gale Banks: A History of Performance<br/></span></td>
</tr>
<tr>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Member2Member</span><br/>Third Generation Steering Box Upgrade</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Third Generation HVAC Blend Door Repair<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">First Generation</span><br/>Throttle Linkage Ball Sockets • Axle Gear Ratio Change • Front Suspension</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • No Power Steering</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">12-Valve Engines</span><br/>Intake Grid Heater • Smoke From Under the Hood • Engine Stumbled and Died • NV4500 Output Shaft Seal • Fuel Pressure Gauge</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Fuel Pressure Gauge</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Fuel Leak at Quick Disconnect Fitting</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">24-Valve Engines</span><br/>Transmission Trouble • Clutch Engages Differently Than Normal • Intermittent Dash Gauges • In Tank Fuel Lift Pump • Clutch Noise</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Transmission Governor Solenoid and Pressure Transducer</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Boost Fault Code, Reduced Power</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Heater Core Replacement</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">5.9 HP CR</span><br/>Squeaking Sound at Transmission • Injectors • Oil Smell in the Cab • Bo Backup Lights • Transmission Leak</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Replacement FCA Connector Pigtail and Screws</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Erratic Engine Coolant Temperature</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Key Programming in the WCM</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Injector Replacement</span> • 48RE Shifting Problem</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Diagnostic Trouble Codes for 2005 Turbo Diesels</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">6.7 HP CR</span><br/>Exhaust Brake Question • Lower Radiator Hose • Engine Oil Leak</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Water In Fuel Sensor</span></td>
</tr>
<tr>
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Fourth Generation</span><br/>Air Conditioner • 2-Wheel Low • Change Engine Oil Indicator • Ticking Engine Noise</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Replacing the Fuel Filter</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Dead Batteries</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Automatic Transmission Jerk/Clunk</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Intake Baffle</span></td>
</tr>
<tr>
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold"><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Technical Topics</span><br/></span></span></span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt">Technocreep and Your Turbo Diesel Truck</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">TDReview</span><br/>Performance Parts Update 2013</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Blowin' In The Wind</span><br/>The 2013 RAM Debuts at the New York Auto Show</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">TDResource<br/></span></span>This Year's Technical Service Bulletins</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Idle Clatter</span><br/>New Member Basics • Oil Change • Issue 78 TSB and Warranty • It Quits Pulling • My Truck Became A Boat</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Check Fuses First!</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Dodge Brake Controller</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Changing the Water Pump</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Ranch Dressing</span><br/>Thank You TDR Members</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • What To Buy?</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Driverless Trucks </span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt">• New Truck Update</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • TDR Driving Etiquette</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Have Ram, Will Travel</span><br/>Interesting Products at the 2012 SEMA Show</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Let's Talk About SCR and DEF</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Back In The Saddle</span><br/>Reflections - Road Trips</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Banks Ram-Air</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Front Bumper by HERD</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Mirrors</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Brake Line Upgrades</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Dana 70 Update</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Want a New Turbo Diesel...But Don't Want to Buy One?</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> </span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">TDRV</span><br/>Lower Truck Bed Height</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Max Tow Transmission Shifting</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • 7-Way Trailer Receptacle in Truck Bed</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Fifth-Wheel Pin Box</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Truck Camper Battery Questions</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Refrigerator Won't Cool in A/C Mode</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • Fifth-Wheel King Pin Stuck in the Hitch</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • 2012 RV Industry Observations</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">From The Shop Floor</span><br/>HVAC Problems/2006-Newer 2006 Mega Cab</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"></span></td>
</tr>
</tbody>
</table>
<br style="COLOR:rgb(0,0,0)">[/RAW]
