Temp. Gauge Question?
paint remover
steering column
Got a new 5er (new to me) and I'm in the process of getting the truck ready for a trip to Colorado, Wyoming, Idaho, Montana, etc. in late August. I'm installing an ebrake and gauges. I have an HO, 6spd and will install a EGT and Boost gauge.
I'm wondering if it is worth the time or expense of installing a temp. gauge to monitor the rear differential temp? The expense will not be much of a holdback, but figured while I was doing the install, the three place gauge pod would be easier than a retro-fit later?
All you towing gurus, is this worth the trouble or should I just forget it? I will probably install a Mag-Tech rear cover at some time in the future. Thanks in advance for the advice I know I'll get. :D
Dave
Its nice to have, but in general, it is not going to do much for you. A rear end has no cooler or pumps or anything like a transmission does so tempature readings are not as critical. You cant diagnose anything with a read end temp gauge like you can a trannie temp gauge. With good synthetic gear lube and a Mag Hytec you should be fine.
I think you should add another gauge, but it should be a post filter fuel pressure gauge. I personally feel it is more important than boost.
If you did add that temp gauge, you could add sensors all over the place and then switch between them to amaze and astound your friends... (and check temps)
