OK, Ok, so I'm new.
There now that that's out of the way I can get to the questions that I still have not found answers for yet.....
1. Torque Converters locking up at XYZ MPH. Ok, I am able to follow the theory behind the transfer of power and temp due to slipping and the desire to 'lock' so that a higher percentage of power is transferred versus 'lost' to the fluid etc. BUT, how do you tell thru feel, sound, whatever, when your TC is or is not in locked up state?
2. Lockers. Are there any (ARB, Detroit, etc) lockers on the market that, a. fit the 02 Dodge Ram 2500, b. Don't require the complete replacement of axel housing, c. Can be turned on/off easily?
3. Scan tools. Is the ODB2 compatible with our trucks? Do you have to have a certain software package/update to work? Or do you have to go to the dealer and rely on their ($4,300!!!!!) system, nevermind the $78 "diagnostic" fee, to tell you the IAT sensor is dirty?
4. Air Compressors and Resevoirs. What size is 'most common' and what would the recommended be for running air tools, air horns, and tire inflation.
5. Shocking ground? Do you fuse both sides of power or just the positive cable feed when installing power runs from the battery to say a brake controller/Air Compressor/stereo/etc? I've heard both but that seems to go against what I knew about having a grounded system (the truck).
6. Grossly overweight? Can the addition of aftermarket items (Shocks, airbags, more leaves, etc) raise the GVW or is written in stone that if you have a camper on and you get into an accident you will be found liable due to an overweight vehicle and your insurance co. dumps you? No, this is not from experience.....
7. Aux fuel tanks. What's with the terms transfer versus aux? Don't they both a. hold fuel, b. put fuel in main tank when needed, c. look great?
Anyway, sorry for the long one post rather than a bunch of individual, trying to be efficient. If you can answer one or all of the above, please do!
Brian
Brian
