Engine/Transmission (1994 - 1998) the best 12 V set-up
Engine/Transmission (1998.5 - 2002) NV5600 mount replacement
Piers, What type of gauge do I get for the BD brake?
98 3500 12v 4x4 Quad Cab SLT Larimie, All the bombing parts accumulating on my workbench. A few more on order, and a few coming from Santa.
80 Porsche 911 SC Turbo Look Porsche Club Racing Trackcar, Totally Bombed
Cannondale Killer V 900 SL
Any mechcanical pressure gauge will work, we do make a gauge kit, it is part # 1030550
Piers, BD engine R&D
Originally posted by Piers:
The old rule of 300 degrees difference is only somewhat accurate on an engine producing 20 lbs or less of boost. Once you get above 20lbs boost add 10 degrees for every lb of boost plus the 300.
675 post turbo
300 added
300 = 30lbs boost
1275 total real time temps
As Chris stated we can bury an 1800 degree pyro in seconds if we want, it's how long you hold it there that matters. What we can get away with in a 12-15 second 1/4 mile run is not what one can get away with while towing.
I have my probe pre turbo. Does that mean if I wait untill it reads 300 the reading post turbo would be 0? Just a question. Not ment to p*** anyone off.
96 2500 4x4 Driftwood auto Waren 4x boards pyro,boost,trans temp on a piller mag hytec trans
Pre & post turbo temps can be a little as 50 degrees difference, too as much [as I have seen] 550 degrees. Cruising around or warming up an engine with no load there is'nt much difference, it's when you start pouring the boost to the engine that you see the bigger differences.
Thanks for the information. I was just wondering because I usually wait untill it drops to 300 before shutting the engine off, but sometimes it seems to take quite a while to get there and this is not after a hard run. Just normal around town driving. Now that the outside air is cooler, 300 comes pretty fast.
I have installed many Pyrometers on heavy diesel applications. Our rule of thumb was to always install post turbo and add 100'degrees per inch from turbo. This same rule would probably work pre turbo only subtract.
95 Dodge 2500 Luverne grill guard,headache rack,running boards and Amzoiled. Soon to be mildly bombed.
Originally posted by KatDiesel:
<font color=blue>I recommend :
remember me when I was smoking!!!!!!
wrench
Ooops oh wait thats not a diesel... ... .
If it's smell fuel, bring it over!!
Griff996
I use a 12v solenoid to switch my boost gauge supply line from the intake to the exhaust. The ebrake power is used to switch it when the e-brake comes on. It automatically switches back to boost when the e-brake goes off. All automatic, no extra gauge to buy and mount. Works absolutely perfectly. Only problem is you need at least a 50psi boost gauge.
E-mail me and I will help you locate the parts needed.
Larry
1972 Chinook class C with 96/215 5spd, 4/5" exh, 4"BD, MagHytec, 85gal fuel, K&N RE0880, AutoMeter, 370's, BD gov kit, BD afc kit, 16cm, 16%btdc, yada-yada-yada
www.fostertruck.com/cummins
Larry- I already purchased a triple mount with tweeter and installed it with my new killer sterio system. From my last truck I had a 0-50 Ultra light-EGT-and transmission. Did not think when I purchased this mount that I did not need a 3rd gauge so to speak. I am just trying to fill up the 3rd hole with an Ultra light of some sort. Maybe a pressure gauge for the brake, maybe a clock. Not sure yet. Maybe an air tank gauge because I am planning on putting in some air bags for the slide in were getting.
Thanks for your concern and advice.
675 post turbo
300 added
300 = 30lbs boost
While breaking several rules this weekend, I had the "mule" up to 875-900*F (post-turbo)and 28-30psi.
(towing the untagged $50 trailer up some short, steep hiway grades @ approx. 95-100mph) So, my realtime temps were closer to 1500 than the 1200 that I was assuming. #ad
Fortunately, those blistering episodes were short... (but sweeeeet!!)
mildly BOMBed 98. 4 1B7KF23D4WJxxxxxx-- BD's #5 plate and 210HP injectors--BD Brake and the associated transmission bomb goodies (except for TC,currently), 4" open exhaust (short),Psychotty, camper shell, Warn front receiver, G159Unisteels on Rickson 19. 5's. . CD player is bone stock, so are the seats. PrimeLoc, also remote spin-on filter for the auto trans... Pyro,Boost and Trans temp from Isspro,
Westin nerf rails(black),
bent welding rod to hang celphone on dashboard...
240HP on Dynojet from 75-105mph drumspeed.
Well, in light of the recent TDR mag... . 10 years back, I thought this was a fun read. Kinda cool how much has changed since 2000.
D
