Originally posted by Piers:
The old rule of 300 degrees difference is only somewhat accurate on an engine producing 20 lbs or less of boost. Once you get above 20lbs boost add 10 degrees for every lb of boost plus the 300.
675 post turbo
300 added
300 = 30lbs boost
1275 total real time temps
As Chris stated we can bury an 1800 degree pyro in seconds if we want, it's how long you hold it there that matters. What we can get away with in a 12-15 second 1/4 mile run is not what one can get away with while towing.
While breaking several rules this weekend, I had the "mule" up to 875-900*F (post-turbo)and 28-30psi.
(towing the untagged $50 trailer up some short, steep hiway grades @ approx. 95-100mph) So, my realtime temps were closer to 1500 than the 1200 that I was assuming.
Fortunately, those blistering episodes were short... (but sweeeeet!!)
mildly BOMBed 98. 4 1B7KF23D4WJxxxxxx-- BD's #5 plate and 210HP injectors--BD Brake and the associated transmission bomb goodies (except for TC,currently), 4" open exhaust (short),Psychotty, camper shell, Warn front receiver, G159Unisteels on Rickson 19. 5's. . CD player is bone stock, so are the seats. PrimeLoc, also remote spin-on filter for the auto trans... Pyro,Boost and Trans temp from Isspro,
Westin nerf rails(black),
bent welding rod to hang celphone on dashboard...
240HP on Dynojet from 75-105mph drumspeed.
