Just got a call from the machine shop and out of both heads are cracked one is cracked between the valve seats and the other has cracks in the valve seats that extend passed the valve seats
Were they both used heads? I've never been able to re-use 12 valve or early 24 valve head when replacing gaskets as they have always been cracked.Just got a call from the machine shop and out of both heads are cracked one is cracked between the valve seats and the other has cracks in the valve seats that extend passed the valve seats
I imagine that’s what will probably happenThat is a really annoying outcome. Could the two heads be welded together to be used as a mail box post?
WhenI paid $1750.00 for a new head from cummins when I rebuilt my engine. New casting, new valves ,springs, guides, retainers and seals. Just bolt it on. It was cheeper to go this way than rebuilding the head off my old engine.
What did you do to itPower Driven Diesel $1540.00
CPP Diesel $1750.00
Fleece Performance $1888.95
Shipping isn't that much.
Mine went a little more.
I did some work on it.
Ported valve pockets and ports, bronze valve guides, larger valves, fire ringed.
As far as I know (up to 2005), Tupy does all of Cummins casting in Brazil.
I didn’t realize poopy was synonymous with quality? I know of 5 different cracked 53 blocks they didn’t cast right .I was just surprised to get Tupy castings for that kind of money.....heck, I paid more than that for a set of 5.2 Magnum Chrysler cylinder heads!
Well I really don’t have 2000.00$ laying around so far I haven’t bought anything don’t know what I’ll do for sure I know of one wrecking yard I may try see what they haveSeems like best bet world be remanufactured from Cummins or a well known vendor that'll warranty it. Beats screwing around with something used that you don't know has a problem till the machine shop calls... that you've learned right
Didn't Tupy cast nearly all 5.9s? Seems like I've always seen that cast into them.I didn’t realize poopy was synonymous with quality? I know of 5 different cracked 53 blocks they didn’t cast right .
