Originally posted by Mark_Kendrick
What are the pop-off pressures and fuel flow ratings??
If you pump less fuel it's easy to do it faster. I did some calculations... at 50psi boost and 17:1 CR there's 1100psi of pressure in the cylinder about the time injection happens. depending on timing before TDC this is greatly reduced, but it's some interesting figures.
and if each cylinder gets 30cc in a smaller engine and we get 50 or 70cc it would be a huge difference in hydrolic requirements.
Mark, you bring up an EXTREMELY important point... ... . the smaller engines can and do run at those higher RPM's, but since the CTD needs a much larger fuel volume to run those RPM's what do you think would happen to the VP44 at 4000 rpm?
What do you think the duty cycle for the little solenoid doohickey is at those RPM's to allow enough fuel volume to produce 500 HP at 4000 RPM? Wouldn't you think it would be close to meltdown of the coil windings? Do you think the VP44 can withstand the forces required to pump greater than 70cc/min (honestly I have no clue what the flow rate is) at a pressure greater than 23000 PSI for an extended period of time?
Only if the coil is superconducting and the pump is made of "Unknownanium".
just a couple of thoughts... and no "missinformation" this time!
