BHaner said:BBQ Juice... You got a garden hose?
Devan Manis said:no N20! only LP and water and don't ask why.
Green Machine said:Yep I gots one or two of them sitting around the house.
You’re going to half to sit inside the cab with me and pinch the garden hose to apply just the right amount of BBQ JUICE.
Should we bungee the tank in the bed or just put it behind the seat this time?
SRadke said:Is that T58 compressor going to work for our turbocharged weed wacker? It's gunna need a big shot of Nos to get it to roll... ...
Diesel Freak said:I hope you are not talking about these useless things.
Mhannink said:no that wasn't it. i thought they where like the first ones posted here i guess not my bad
Diesel Freak said:tsi_2baad4u, would you care to elaborate?![]()
SRadke said:My drivers are unfortunately union and they'de decided my cart is too fast to lack a five point harness and roll cage so unless I can come up with another driver I'm gunna have to do a full retrofit.....
tsi_2baad4u said:Sure. I'm going off of cars that have actually made the HP on a 60lb/min compressor. Don't forget Cliff, the DSM guys don't mind driving a turbo waaay off the efficiency map.My stock turbo blows pretty much nothing but hot air at about 18psi (stock is 10. 5psi). We've found that on VP C16 (117mon) that little turbo makes "mad powa yo" at 25psi.
:-laf Seriously though, if you use the miracle fluid VP C16, we drive turbos well out of their range and still make power despite the hot air. Try some in your diesel. :-laf
As for the HX35, I thought I remember seeing it listed as a . 35Kg/sec compressor. That comes out to a 46. 3lb/min rating. The HX40 is listed as a . 44Kg/sec compressor, or 58. 2lb/min rating. Those seem a little more realistic to me.![]()
