Originally posted by Tony T.
At 60k the dealer told me I needed a rebuild on the transmission... said the pump was gone. I noticed that he (their best transmission guy) didn’t know that there were several pressure ports and didn't know how to do a pressure test. (have book - can read) So I borrowed a gauge and followed the instructions to do a complete series of pressure tests and with the help of this forum found the problem was the Governor pressure sensor and transducer. I changed them out and no more problems. (as long as I change the fluid every 20k and adjust the bands) So to answer your question, the transmission seems to a very weak design. Raise the HP and roach the transmission. Also, it took a while to learn how the transmission works, which gear it was in, torque converter lockup etc. After you learn where the transmission is in the shift pattern and read this forum to learn how the weak ass torque converter works, you can then tune your driving habits to protect the transmission. The shift points you described are designed to protect a weak transmission. The only reason mine lasted as long as it has is that I remain..... "Unbombed to the MAX"
Thanks for the reply back Vinconco I'm planning on changing fluid every 25K an checking bands also. Also plan on remaining stock. Maybe I'll get the same out of mine that you have so far. Oo.
