yes, and by the way, I did double check the ground runs to the A4 terminal. The ground to the speed sensor and the TPS were real good. My test drive today showed the Overdrive was activating at the correct speed (about 45 to 50 mph), but I did notice a little "slipping" or what I think is termed hunting. That usually happened before when there was a TPS issue. I will check into this more closely tomorrow. I think I may need to adjust the linkage/TPS, although the idle TPS reading was 1.02 volts, which is within the +/- .2 volts. I did not check the wide open throttle reading, but usually I found if I set the idle voltage good, the WOT was good also.
It's a bit late in this discussion, but I did want to share some historical info on this particular truck for those interested... aprox at 20k miles into this trucks life, the trans started "slipping"or hunting between gears. Dealer said nothing was wrong with it because the symptoms would not present itself when in for service. Every six months or so and sometimes on a rainy day, same thing.
Just by chance, I came to find a "sort of" solution...Just pop the hood, grab the main harness on the driver side of the engine, and give it a good shake...Fixed. Same fix when my complete set of gauges would "jump" or bounce and dash warning lights would flash in unison. Shake the harness, fixed for another six months. I tried many times to investigate the reason, but would never find out why, although I never completely opened up the harness.
I still don know why, but maybe this issue is by chance, part of the reason. Again, the dealership could never find the issue because no codes were present and the symptoms were not present when I waited the two weeks they needed for an appointment. Who knows, maybe in six moths I will know....
with all that said,
You guys have probably noticed I tend to think the worst, looking at all kinds of possibilities like bad PCM etc. I guess I just ask all kinds of questions as I go down the troubleshooting path. Please bear with me...Im still learning bit by bit even though I've been on this planet over 64 years!
As I do each repair on the truck, I pick up a better understanding of the many systems and how they interact and work together.
Thanks again for all your help and most importantly, your valuable time.
