I'm sure you've heard this before, but I have an intermittent throttle problem. It started with a check engine light, still ran good, set code for apps low volt. I checked connections, disconnected Banks box, cleared code, everything ok for a week. Apps code came back, now I feel brief hesitation at times. Cleaned all grounds et'c, it went away for another week. Now its back. I will loose throttle completely, shut it off, restart, continue on with no more problem. Now it has apps low volt and idle validation switch dont agree codes. Is this a common problem? Is the apps going bad? Should I be looking at some other cause? I'd hate to buy a new apps( I heard they're pricey) and find out it doesn't fix my problem. Any insight would be greatly appreciated.
